end cap wrench size for 2003 pathfinder vq35de
USA
I can find the exact size cap wrench for my 2003 pathfinder VQ35DE motor Original from Nissan filter OEM not aftermarket filters
every time I try a parts store ,NO good , too loose and Nissan don't sell these cap end parts any one know the answer. I do not want a span type wrench because you cant tight up with those
I have the exact same year PathFinder and engine, 146,000+ miles.
After you drop the Rock Shield the filter is just to the left of center.
A simple claw wrench or just my hand is enough force to twist it off.
After an oil change I simply twist the filter on by hand until snug, back it off by 1/4 turn, and then snug to fit.
Over tightening filters is often done by DIYers and shops.
Mola
I assuming you are removing? Tightening should be done by hand and unless your Superman you cannot really over tighten by hand.
For end caps they sell a few that have 3 adjustable spring loaded claws. The claws bite as you exert pressure. They sell on Amazon and other places. They have 2 sizes, medium and large.
I broke spot welds on a HF cap wrench, but the one with 3 claws got the filter off.
Originally Posted By: Rand
IMO if you need to use a wrench to tighten you are doing it wrong.
I know what your thinking , you can not get your hand up in there to hand tighten so common sense would tell me about 3/4 th of a turn would do it with a wrench ,
that filter must have been very over tightened for the welds to brake , but it happened s.
see the problem with a claw wrench is that its so tight to get my hand in there [ me Big Hands] , that I need a cap wrench just to give it about 3/4 of q turn and the claw type only loosens the filter I don't think in the opposite direction it will tighten it ,maybe I'm wrong ,just figuring. thanks
Originally Posted By: Eddie
Try Fram wrenches. I found my bit-of-an-odball cap wrench at Walmart. Cap wrenches don't need to fit perfectly. Ed
so far Ed I went to wall mart , no luck , then to auto zone, haven't tried Napa or Advanced auto yet but your on the right track for me thanks
I am old enough to get a senior movie pass at Regal Cinema. I have bought new oil filter wrenches when needed. I might have 20 or 25 including some I got from my Dad. Right now a regular band wrench works fine for Jeep and Dodge Ram. Bobcat is another thing all together as is boat and snowcat.
Can never have too many tools.
I use a cap wrench on mine to get a better feel. I tighten the filter wrist tight with a 5 inch long 1/4'' drive ratchet. And when I say "wrist tight," I'm talking about the way the ratchet is held in the hand in order to limit torque.
Right Donald I also have lots of extra tools
Yes your right about that knowing when to stop ,I have been working on cars and trucks for 45 years and still learning .
