I really like my hand pull emergency brake vs the On or Off electric brake. I like the safety feature of being able to modulate with the hand brake. Ed
Although I get what you're saying, a hand pull brake is not designed for use as an "emergency brake". It is designed for use as a parking brake.I really like my hand pull emergency brake vs the On or Off electric brake. I like the safety feature of being able to modulate with the hand brake. Ed
Scott
My wife's Audi A4 quattro is a stick as is my Hyundai Elantra Sport, so we actually need to use the parking brake.
Her car has an electric parking brake and mine a hand pull parking brake. I much prefer the good old hand pull parking brake
over hers.
My brothers 2019 F150 has an electric parking brake.
Nissan went back in time on the 2020 Nissan Sentra which now has a FOOT OPERATED parking brake.
Nissan made a short video of it since most younger drivers have never seen such a parking brake:
I agree with the ability to modulate, even though I can't think of any reason to use it halfway
Maybe it's useful to bed in the rear brake pads if you have rear discs and the parking/emergency brake runs off the rear pads, then you can pull it only a few clicks so that the pads rub against the rotor but not enough force to fully stop the car. But even then, there's no real need to do that since Akebono and some other companies say no special bedding procedure is necessary.
I thought almost all hand operated levers used shoes inside the rotor.
how would you actuate a hydraulic caliper with a cable? (curious)
The foot operated where you push in again to release them are only parking brakes. The lever style are dual purpose and yes it is very useful to be able to modulate them in an emergency situation, IF you are practiced at it that can make a difference.
-snip-
However it can't be an emergency brake if you don't remember to use it, same as some other emergency reactions like using the key (on vehicles that still have one) to turn the engine off in a runaway throttle scenario.
Electric does not really simplify issues as much as compound them. It creates more complexity, more failure points, typically shorter life before failure (as long as you USE the manual brake so it does not seize up prematurely, AND you remember to disengage it once driving away, lol), and higher repair cost, and still has mechanical failure points.
I can use a wrench to pound in a nail. That doesn't make it a hammer.
Passenger vehicles don't have an emergency brake. Passenger vehicles have a parking brake.
