Here was my inquiry about the compatibility of ATL with WS.
Regarding the new ATL trans fluid. I have a 07 Toyota Tundra that i use strictly for towing most of the time. I've come up on 25k miles now, and would like to incorporate the new ATL fluid into the transmission. What do you recomend? I'm thinking of just doing a drain and fill at this time, then continuing this regime on every oil change. Would there be a problem doing this? Will the ATL fluid be 100% compatible in my WS transmission? Thank you for your help. Your quick response would be greatly appreciated.
And their response was:
Thank you for contacting AMSOIL.
In response to your inquiry, AMSOIL ATL would be compatible with the Toyota WS fluid and if you drain and fill approximately 3 times you willl have exchanged out approximately 90% of the oil.
Thanks again for the opportunity to respond to your concerns. As always, please feel free to contact us again if we can be of further assistance.
Sincerely,
Steve Pelach
Tech Services
Wow! D&F 3 times gets me to 90%? Is this possible in a 11 qt total capacity trans? I'm figuring about 4 qts per drain, but i don't know for sure.
Any tips please comment:
Sincerely,
Steve Pelach
Tech Services
