This is in a three year old high end condo built by a very reputable bulder in Toronto.
Two questions - Why would someone need the outlet inside the cabinet? What would they plug in?
Isn't it against code to have receptacles inside cabinets?
True. Should have said it has to be GFCI-protected.The GFCI could be in the breaker panel.
Yes, Bathroom Vanity.I think the OP is puzzled because this is a bathroom vanity -- no disposal or dishwasher potential.
If it was DIY, I'd be surprised that the homeowner used BX cable though.An electrician would have made his own hole....
My customer is the original owner of this condo and he did not put it in, it was put in by the builder.To me, it looks like that was put in after completion.
An electrician would have made his own hole....not pulled it in through the drain hole.
If that is an outside wall, maybe someone feels like it needs a little heater in the winter.
Otherwise...who knows.
And clamped the cable down close to the box. This definitely looks like a professional installation.If it was DIY, I'd be surprised that the homeowner used BX cable though.
In highrises, the hot and cold risers are almost always just behind the vanity and there is never any waiting for the water to get hot.Point of use water heater, a circ pump.
You would sure get a big dose of fragrance when you opened the normally closed door.Good place for a Glade plug-in or an ultrasonic pest repellant
