I don't have an outlet in my water closet or else I'd have an electric bidet in there.In a bathroom? Then it's to power one of those electric bidets.
You might be on to something, there is a Toto toilet in there, which needs to be plugged inIn a bathroom? Then it's to power one of those electric bidets.
That plumbing job don't look anything close to "high end" to me.View attachment 242984
This is in a three year old high end condo built by a very reputable bulder in Toronto.
Two questions - Why would someone need the outlet inside the cabinet? What would they plug in?
Isn't it against code to have receptacles inside cabinets?
The drain is well done, very nice, except for a missing wall flange.That plumbing job don't look anything close to "high end" to me.
Why is there a need for point of use water heater in a high rise? There is always an endless supply of hot water.Power for a point of use water heater for instant hot water or an automatic touchless faucet.
My customer is the original owner of this condo and he did not put it in, it was put in by the builder.
Modern condos are very well insulated and heated, unlikely anybody needs extra warmth.
This was a show apartment in this building, but I can't think of any reason why a show apartment needs an outlet inside the vanity.
Are you talking about inside your cabinets? I’m not sure what the OBC says but the Canadian Electrical Code forbids receptacles inside cabinets unless it is for a couple specific uses such as microwave, hood fan, dishwasher or you install a door switch that disables the receptacle when the door is closed.
https://forums.redflagdeals.com/does-obc-code-allow-outlets-inside-kitchen-millwork-2449297/26-720
h)I) a receptacle shall not be placed in a cupboard, cabinet, or similar enclosure, except where the receptacle is
i) an integral part of a factory-built enclosure;
ii) provided for use with an appliance that is suitable for installation within the enclosure;
iii) intended only for a microwave oven;
iv) intended only for a cord-connected range hood; or
v) intended only for a cord-connected combination microwave oven/range hood fan;
i) except for cord-connected dishwashers, in-line water heaters, garbage disposal units, and other similar appliances, receptacles installed in cupboards, cabinets, or similar enclosures in accordance with Item h) ii) shall be de-energized unless the enclosure door is in the fully opened position;
Not necessarily the homeowner who put it in. In fact, a lot of high-end condos have rules about who can do that kind of work in their building.If it was DIY, I'd be surprised that the homeowner used BX cable though.
More annoying is why the plumber did not put a trap in without a cleanout plug on the bottom, especially on a bathroom sink. Future work taking the trap apart to get the hair and gunk out?View attachment 242984
I always install the P-traps with the clean-out but occasionally the clean-out is a hindrance.. If sending a snake in from the top after just removing the pop-up plug, the cable head gets caught in the clean-out recess and the clean-out plug has to be removed to guide the head past the recess. A snake is necessary if the clog is in the vent tee inside the wall.More annoying is why the plumber did not put a trap in without a cleanout plug on the bottom, especially on a bathroom sink. Future work taking the trap apart to get the hair and gunk out?
I guess if the clog is in the wall the trap comes off anyway, maybe condo issues are a little different than the ones I get from my family. The clean out seems to get the job done with minimal work on my part crawling under the cabinet.I always install the P-traps with the clean-out but occasionally the clean-out is a hindrance.. If sending a snake in from the top after just removing the pop-up plug, the cable head gets caught in the clean-out recess and the clean-out plug has to be removed to guide the head past the recess. A snake is necessary if the clog is in the vent tee inside the wall.
The vast majority of traps I come across in Toronto have the union but not the clean-out, like the one above.
Wouldn't you want to bring in MC wire vs BX, IF you chose armored cable as your install choice, especially in a known very wet/possible very high steam bathroom GFCI scenario? Nothing like a green wire attached directly to the grounding bus bar? And wouldn't BX be a code violation in a residence/non-industrial setting to top it off?Not necessarily the homeowner who put it in. In fact, a lot of high-end condos have rules about who can do that kind of work in their building.
It's possible that an electrician dropped the wire there before the cabinet was installed and the cabinet installer ran it through the drain opening being lazy.
If I had done that before the cabinet install, I would want my own hole and would bring the BX in through the back of the box where you wouldn't see the BX in the cabinet....just the box add receptacle.
After the cabinet is installed... I probably would have done it the way this is done.
I wouldn't want to butcher up the back of the cabinet.
