I just wanted to add that the reason for reduce valve overlap is obvious to many and thats emmisions . The reason for reduced valve train weight will not be to many here .
The now near common place use of non-symmetrical cam lobes and computer generated models of vs the hand plotted mathematical formulas such as the Fourier Series of yesteryear allow for a much smaller base circle than older designs . Anytime you can increase the valve lift without increasing the duration and resulting valve overlap you'll have problems keeping the lifters/followers/valves controlled without increased spring pressures and racing oil in certain applications .
The next best way to control the valve opening/closing events are to lighten the valve train....... the results and applications from racing programs and technology learned from are used on the street in many grocery getters today
