Originally Posted By: SuperBusa
Originally Posted By: SWHeat
What Gary said. Flow dynamics seal the felt to the media...even IF it were not bonded at all and floating in space above the media.
But how could that be if Gary always claims that there is hardy any significant PSID across a filter's media?
Seeing how flimsy the glue job was on the photos above, I'd be leery of using a filter like that. Pressure is going to cause the oil to flow through any unsealed gaps before it goes down a more restrictive path. If there are unglued gaps on the end caps there will always be some oil getting through them.
Go buy one and cut it open.
You'll see that the ends are support against the element by the can and the valve.
And all the ones (more than 1 and I've posted MANY photos of them HERE for all to see) NONE OF THEM HAD HOLES OR END CAPS COMING OFF. All of them REQUIRED some force to take off the end caps.
Also, in a few years ALL filters will be made like this or cartridge filters since they are looking for ways to make them more "green".
What will you guys do then?
