I used it several days ago. I ran the compressor with and long air nozzle into various openings in the frame. I was surprised how much Sandy grit, and leaves came out. I kept doing it until it was clean.
Then I used the Eastwood internal frame coating. It worked real well with that 2’ tube. I was surprised how much coverage it did!
I had the front end, completely disassembled. 160 thousand miles I was replacing everything. I use the needle scaler, a cordless drill with various wire brushes. I got easily 99% of the rust removed. I sprayed that with the rust reformer paint. Waited a few days and spraying black flat enamel.
Also completely cleaned up both knuckles. I’m not sure if I can coat them with something? They probably haven’t looked this good in many years!
I’ve got a couple more parts arriving today. Then I can start putting it back together.
