I did the passenger side with an air needle tool, cordless drill with various wire wheels. And I used the air compressor nozzle to blow out loose debris inside the frame openings.I've used it, the green one from Eastwood and it's awesome. I didn't use it inside the frame, used it for surface rust around the firewall in the engine bay, more like the top of the fender area. Since it's sensitive to UV (without a top coat) the sun doesn't shine in those corners of my car anyway. Reminds me of that candy coating dip they used to offer at the ice cream shop. Goes on wet, then hardens to a candy hard coating. I know that's funny but that's how it looked to me as the green coating dried/hardened. You could tell it was a runny type thin liquid, it crept into all the cracks/crevices, which is a good thing! I used a inspection camera to watch it up close and it looked like the rusty (surface rust) soaked it up like a sponge! I think it took 24-48 hours and it was dried and hard.
The whole point of stopping rust in its tracks is stopping any oxygen from getting to it anymore and this stuff does it very well. Yes I'd say it's like POR15 but without all the steps to make sure the surface is prepped,etc. All you need to do is blow out any debris and then spray! boom! done..![]()
That's a great point to use tape to make sure it stays in there, but if it's over applied all that happens is once the liquid seeps into everything, the rest just turns into what looks like frosting on a cake. Sits on top and hardens, no problem doing that. Definitely get a tarp under your vehicle, this stuff can go everywhere especially when sprayed full tilt from the can. You could use an inspection camera to look in after you spray to make sure you have full coverage. I found that after I got done and it dried I touched up some areas I missed.I did the passenger side with an air needle tool, cordless drill with various wire wheels. And I used the air compressor nozzle to blow out loose debris inside the frame openings.
I read one comment on YouTube where he said put duct tape over the frame openings. This way it didn’t leak out. I’m going to try it that way. Then remove the tape the next day. This way the Eastwood product stays inside
Thanks. I didn’t know that another product was needed with the Eastwood frame injection product.That's a great point to use tape to make sure it stays in there, but if it's over applied all that happens is once the liquid seeps into everything, the rest just turns into what looks like frosting on a cake. Sits on top and hardens, no problem doing that. Definitely get a tarp under your vehicle, this stuff can go everywhere especially when sprayed full tilt from the can. You could use an inspection camera to look in after you spray to make sure you have full coverage. I found that after I got done and it dried I touched up some areas I missed.
But then again I wasn't trying to coat inside a frame, spray a little burst here and there. Might be different if you go full spray. Oh and definitely use a degreaser like SEM products Sem-Solve or the Eastwood pre-prep cleaner into the spray hose, will make sure it stays clear otherwise it'll clog up solid with the frame coating paint.
Oh I meant to clean the spray tubing out from the internal frame paint. Just take off the nozzle/button from the frame coating can and attach it to the pre-prep Eastwood can, spray and it'll remove any residue in that tubing. Otherwise if you wanted to re-use it you'd need to buy another spray tubing.Thanks. I didn’t know that another product was needed with the Eastwood frame injection product.
How exactly do these other products work? Do you spray them into the frame first? Or spray them into the Eastwood internal frame injection tubing?
I want to understand it completely before I start.
Thanks for any clarification.
Makes more sense to use something that neutralizes the rust and then coats it good then dry's well. Then later on oil it all you want.I'd use fluid film with an air compressor gun and long hose. lot more power than the spray cans do.
I’ve got all the front end metal cleaned up of rust (@ 99%). I sprayed everything with “rust reformer”. Let dry a few days. Today I’m hiring everything with black satin spray enamel. When the Eastwood internal frame coating arrives I’ll get that inside the frame.Makes more sense to use something that neutralizes the rust and then coats it good then dry's well. Then later on oil it all you want.
All oils do is cover the rust and it keeps on rusting, may slow it down some but?
Fluid film stops the rust and penetrates down. I worry a coating dries and then can get flaky and develop rust underneath.Makes more sense to use something that neutralizes the rust and then coats it good then dry's well. Then later on oil it all you want.
True but the oils creep into the rust and stay there. I've found that any of the oil based undercoating will stay on the surface better with a little surface rust to absorb into. They tend to self-heal as well, keeping the metal fully protected and wicking into areasFluid film does not have a rust converter in it like phosphoric acid that the special paints do have and that also helps them etch in so they won't flake away. In other words there is no rust left, but with oils the rust is still there. So ?
I used it several days ago. I ran the compressor with and long air nozzle into various openings in the frame. I was surprised how much Sandy grit, and leaves came out. I kept doing it until it was clean.I have used the green twice it works very well. The tip of the long hose sprays 360 degrees it gets good internal coverage.
