E4OD FLUID HELP
wi
I am up in the air on which atf fluid to get...
i have a 96 f250 with a 460 and a E4OD with 112,000 miles.
I don't know if I should go Mobil 1 ATF or amsoil
or go cheaper with a Mag 1 dex/merc. or little better with kendall?
I don't have alot of extra cash with being in college.
Normally I run amsoil in my rides but needing 18qts at 10$ a quart thats a major hit.
Is it worth the extra $ to go with amsoil or mobil 1?
I can get 5 gallons of mag 1 for 45$ or 5 gallons on kendall for 100$... both say dex/merc and no merc V.
another thing that bugs me is how amsoil atf is like a universal fluid and that doesn't seem right for a E4OD.
Any input?
If the Mag1 meets the specs then use it. You can change more frequently when you're getting it for $9 a gallon.
