The tires that are on it (Toyo Proxes T1R's) are not ideal however. They give up traction even north of 100Km/h with any sort of heavy pedal. I've never had the traction control come on in anything I've ever driven as often as it comes on in this car.
Make sure the tires aren't underinflated. Traction control has a tendency to kick in a lot more if you're somewhat low on air.
By the way, you still owe us interior pics!
You sir, NAILED IT!
Somebody (I assume the dealer) had all the tiers at 40psi.
The fronts are supposed to be at 44psi, the rears at 48psi.
With the correct amount of air in the tires, it is now no longer "don't look at me that way, or I'll spin and engage the TC on you!" happy. I was able to roll into it in third, wind it out and rail 4th with not a hint of traction loss.
You sir, NAILED IT!
