Duralast front rotors
Originally Posted By: zzyzzx
I won't put any Duralast branded products in any of my cars, even my beater.
Because the same part in somebody else's box is better, very broad brush you paint with fella. All of the consolidation in the parts business you think that every store in town has somebody different that tools up and makes 10,000 rotor part numbers?
Agreed.
Re: rotors, iron is iron. A minute or two of careful measuring and inspection will check the machining and quality. Many here mistake a PAD issue for a rotor problem...
Agreed.
I generally agree with you, but in this case it does appear to be a rotor issue.
Originally Posted By: wrcsixeight
I shot my self in the foot purchasing the Chinese duralast rotors in '08 as well as by installing new timken bearings on the duralast races.
Obligatory:
I might be OK with Duralast battery, since I do know it's probably made by JC, Exide, etc. But most of the other stuff, not so much.
Does the video have bias? Maybe. But a new, cheap rotor shown in the video can meet measurement specs and a tech would be comfortable installing it.
http://www.youtube.com/watch?v=J3_Mk5a7vAM
I have an F-250 pickup that gets worked pretty hard and I wouldn't want these rotors on my pickup.
Pay attention to the video at about 8:40 and beyond. That is something that you may not catch with a visual inspection because you are doing a comparison to an old rotor that is worn out.
There is a difference even among China rotors. There's a difference between a Duralast or other housbrand white box part and say an ACDelco, Raybestos or Wagner Chinese manufactured rotor.
There is a difference between iron casting metallurgy, quality control and also rotor casting thickness and vane and hat contruction. Low quailty Chinese castings can even screw this up. Then there's balancing and machining. I'd say most brake problems really are rotor run out problems. It's very hard to tell. You would need a dial indicator and you are looking for less than .002 total indicated run out. But the rotor itself needs closer to .001. It's not all that easy to measure and detect for most installers. Leave alone balancing.
Originally Posted By: Jarlaxle
Near as I can tell, ALL the rotors are coming from China now!
When you're the only source you're the best! The worst rotors also come from China. I don't think any are wholly made in USA or Canada now. Better OE ones come from Mexico.
I just put a set of Bendix I got from Rock Auto on my Durango about three months ago. It was not the Bendix Global but the next one up. The box said they were made in Canada.
I would guess they were quite old stock. Where there any kind of date markings on the box? Where they one of the closeout items on RA?
I recently purchased a set of Raybestos Pro (their mid-grade rotors) for the Hyundai and they were made in China. But I don't remember if the boxes had any kind of date markings.
Obviously, different applications may be different, but I haven't really read of any new production Raybestos Rotors that weren't Chinese.
All is well with my Mexican Brembo's.
I was lucky enough to have a bunch of open road for some bedding in procedures. After 3 hard slow downs from 70 to 20, 55 to 15 and 45 to 15, I did not have to use the brakes for a few miles, and when I did tap them they grabbed harder than ever.
That feeling has not returned, But they grab as good as the duralasts ever did.
China is capable of manufacturing quality, the issue is one never knows which products do, which ones once did, and what you are getting.
I'd gladly pay more for quality, but it seems so many times you pay extra for a name on the box and the product inside is the same as the one in the bottom of the barrel box.
I did not save the boxes and I do not remember if they had a date code. They were on close-out. I do remember that although these had a Bendix Sticker on the box that the box also conatined a Napa part # and either a Raybestos or Wagner part #.
That explains it. I've bought Rock Auto closeout items that were clearly years old. I think you bought old stock from before the production was shipped to China.
Lucky me then. I got the two rotors and a set of Satisfied Brake Pro Performance VS pads(I think these were close-out also)that were approx $80 total shipped.
I used Duralast rotors on my last car and tracked it too. Used EBC Yellow stuff pads and never had a problem with the rotors. The same car I bought some Raybestos Brute Stop rotors and within a year they had radial cracking on both.
Many OEM rotors don't come from China. Also, not made in China does not mean made right.
My mom's 2005 Jeep Grand Cherokee stopped much more smoothly when the OEM Canada rotors were replaced with Raybestos premium from China.
I agree that it's a hit or miss. I had Brembo blanks on my 07 Honda Civic Si, which was driven very hard on the street. Rode perfectly.
Installed Brembo blanks on my 07 Honda Civic EX, which is driven normally and within a few thousand miles, the steering wheel is shacking.
Both times the rotors were ordered from Tirerack. Not sure if one set is China made while the first set was made elsewhere but that's the facts.
I will be replacing said rotors soon. Can't stand when the steering wheel shakes.
