Had my dad snap this shot of the cluster while I was towing the boat up to the cottage. Most of the trip was spent in 7th (tow/haul limits 8th to above 100Km/h) with it being in 8th once we got onto highway 11.
This is not a super heavy load, probably around 4,500lbs combined? A fair bit lighter than our Four Winns, which isn't quite ready to go up to the lake yet.
This truck has the 3.92 rear axle ratio with tow package (trailer brake controller...etc) and oil cooler.
I also had him snap a pic of oil pressure. This is M1 EP 0w-20. Relief pressure on the pump is 75psi, a downshift to 6th to accelerate put it up around 3K and 55psi.
For those not using metric, 108C is 226F, which is quite reasonable. As you can see, ambient temp is quite warm (33C/91.5F) which likely explains the higher observed temp than I saw in the fall when it was much cooler. OE thermostat opening temp is 195F IIRC.
