This car runs the bulbs in series for DRL, so each bulb gets 6 volts. Also the polarity of one of the bulbs reverses between DRL and high beam modes.
Resistors will not change that. Load resistors are for turn signals and brake lights so the lower current of the LED will not trigger the car's burned out bulb detection. Wasting current with a resistor in parallel with the bulb increases the total circuit current back to what is normal for an incandescent bulb.
