Isn't it always about needed viscosity ?
M1 thins.
HPL doesn't.
It's a choice.
M1 thins.
HPL doesn't.
It's a choice.
They'll all thin if the source of the viscosity loss is fuel, which, as we've discussed extensively, is typically the main driver.Isn't it always about needed viscosity ?
M1 thins.
HPL doesn't.
It's a choice.
The M1 already shears. Better ?They'll all thin if the source of the viscosity loss is fuel, which, as we've discussed extensively, is typically the main driver.
By how much? In my M5, which has a massive timing chain, dual VANOS and in general, would be setup to be extremely hard on oil, viscosity loss was dominated by fuel. I know this because the oil was analyzed by a lab that uses GC, which most people on here don't use.The M1 already shears. Better ?
With your M5, cost/benefit would be a factor IMV. Frequency of OCI.By how much? In my M5, which has a massive timing chain, dual VANOS and in general, would be setup to be extremely hard on oil, viscosity loss was dominated by fuel. I know this because the oil was analyzed by a lab that uses GC, which most people on here don't use.
All 0w-40's will contain some amount of VII polymer, likely a similar amount, which means that they will all be vulnerable to some viscosity loss through shear. Mobil has access to the best components in the world, now, whether they choose to USE those components, that's certainly worth debating, as we know they use much more GTL in M1 FS 0w-40 than PAO, but they would be using very shear stable VII's, as they have to in order to pass the Mercedes certs, and I'm sure others.
Even if true we really don’t know how the HPL product acts do we? Isn’t mechanical shear highly dependent upon the application?The M1 already shears. Better ?
However, I personally would not hesitate to use a very robust, very stable oil, albeit very expensive, if I were lucky enough to drive an M5.
Gotta open 'er up from time to time. WOT !
In my case, it has been totally different circumstances.Even if true we really don’t know how the HPL product acts do we? Isn’t mechanical shear highly dependent upon the application?
The Mobil 1 product must pass standardized tests for stay-in-grade as part of the approvals, do we have results if these tests for HPL?
Also are we comparing the same grades here?
I do know. They are both good. They both shear at a similar rate. We build slightly heavier and shear at a similar rate which means we actually will very likely stay in grade longer. However since they are both good I don’t see shear being a problem with either. Going back to the original question the FS 0w40 is the one I would choose of the 3 the OP asked about.Even if true we really don’t know how the HPL product acts do we? Isn’t mechanical shear highly dependent upon the application?
Thanks for the reply. I doubted that ExxonMobil was using inferior VII in one of their flagship products, as neither would you.I do know. They are both good. They both shear at a similar rate. We build slightly heavier and shear at a similar rate which means we actually will very likely stay in grade longer. However since they are both good I don’t see shear being a problem with either. Going back to the original question the FS 0w40 is the one I would choose of the 3 the OP asked about.
David
To be fair, I put "better" in quotes to attempt to indicate the statement was questionable, reallyYou need something better than an oil with Porsche A40 approval? What are you running?
You created a good thread for the sake of discussion !To be fair, I put "better" in quotes to attempt to indicate the statement was questionable, really
