Well, here's a vague overview...
Tests were performed on 4 different braking systems each run with crossdrilled rotors and with blanks. Same pads for each system.
Tests were performed at both the track and on the dyno.
In the wet, at low braking effort, the crossdrilled rotors had significantly more bite (over 50%). At higher effort, the blanks and crossdrilled rotors were much closer. This was thought to be the hydrodynamic wedge having more of an effect with less clamping pressure.
Drilled rotors improved front rotor cooling with higher speeds showing larger improvements. It's very significant but I'm afraid to post the number. Improved cooling was seen at every speed.
Rear rotor cooling was interesting. On one system with high airflow to the rotor, smaller rotors, and many drilled holes, saw higher temps at low speeds, a wash at moderate speeds and it was not until higher speeds there was a temperature reduction. On the model with the larger rotors and less airflow temperature decreses were seen everywhere with drilled rotors.
Apparent friction started higher with the blank rotors with a starting temp of 100C and quickly fell as temps rose.
Apparent friction started lower with the drilled rotors but remained almost flat to 400C resulting in significantly less pedal effort once hot than the blank rotors.
Brake pad temperatures were significantly lower with drilled rotors.
Glazing the pads was almost a non issue with the drilled rotors.
Pad wear under normal temps was very close but as temps rose the pads wore much quicker with the drilled rotors. Pad wear was more even with drilled rotors.
Drilled rotors recovered quicker.
Drilled rotors showed more of an advantage in vehicles with lower airflow to the rotors.
Some of the cracking at the holes was found to be a factor of the design of the hat area causing stress and not heat alone.
Hot Roughness (Hot Judder) was non-existant with the drilled rotors. My TL suffered from this very badly with the stock brakes. As soon as they picked up any kind of temperature they felt like they were warped. It happened at a lower and lower temperature as time went on. This was said to be the rotor distorting unevenly during heat cycles and resulting in high spots that catch brake pad material which only gets worse over time.
The cons of course are a shorter thermal fatigue life, quicker pad wear at high temps, and a whirring noise under heavy braking.
I know it's vague but I think I covered all of the large points. This thing was 28 pages long, lots of neat details.
