this has been a neat thread. I’m surprised this hasn’t been clarified however.
drilled rotors:
1. drilling provides increased cooling
2. Helps outgassing
slotted rotors:
1. Helps outgassing
so, the mods to the rotors have different purposes, they are not the same and were initially chosen for specific reasons when first introduced. If one considers that brakes work best at certain temperatures, one would also want to make sure the amount of cooling is appropriate for their conditions.
outgassing has also been mitigated by pads which simply slice them down the middle.
I have personally viewed hairline cracks starting at the edges of drilled rotors. Flared or rounded holes can reduce the propensity for cracking.
personal opinion: for street use, drilled could cause more problems than gains. Slotted could provide enhanced pedal feel without over cooling or increasing risks of rotor fatigue. Some may not like the noise or the potentially (results seem to vary) shortened pad life.
and a personal thought: if street driven drilled rotors aren’t showing tiny cracks at the holes’ edges after accumulating lots of miles, they may not be thermally stressed enough to indicate the need for additional cooling in the first place.
m
