Originally Posted By: maxdustington
Originally Posted By: Ducked
Here there's no road salting and very few old cars, so you dont see many rusty ones outside the aboriginal areas. However, my car was owned by a surfer, and has been parked near the beach in onshore typhoonal winds. Think warm sea water pressure wash for a day or two, then OH! Canada might not seem so bad.
So you are claiming that coastal Taiwan is worse for rusting cars than rustbelt Ontario, although there are few rusty cars there?
Dude it's ok if you don't understand rust if you have never lived where they salt the roads. I'm just shocked you would try to make the argument that Ontario is less corrosive than a place where it doesn't even snow, that's laughable.
Nope. I'm claiming that my car is an exception to the general Taiwan rule, because it is
(a) Very old and
(b) Has been exposed to sea salt by the previous owner (and to a lesser extent in my ownership) in warm or hot conditions.
Since you, in your opinion, understand rust so very well, I don't have to explain to you that salt in warm damp conditions is much more conducive to corrosion than sub zero, as in OH! salty Canada
i didn't mention any Scottish seaside towns, (and I wouldn't have been talking about typhoons if I did), though of course its true that you can't get as far away from the sea as you can in OH! salty Canada. Roads in Scotland are salted (actually gritted, a mix of sand and rock salt, looks brown) because of winter icing, but this is intermittent and unpredictable, so the roads are often salty well above freezing.
You have to actually read the words, and understand them, in order to extract the meaning. You also have to have enough basic grasp of geography to be able to distinguish between Taiwan and Scotland, quite different and distinct places.
But there havn't been any wars in either lately, so a N. American wouldn't necessarily be expected to know where they are.
Doode, its OK that you think you have the last word on corrosion based on Canadian conditions. Its OK if that's true. Its OK if it isn't. It doesn't matter.
What's unfortunate is that counsels of perfection like this, if believed, (and they often are, because they hook in to "if a jobs worth doing, its worth doing well" etc received opinion that eveyones programmed with) actually promote corrosion.
If you tell someone that theres no point in doing anything but a sandblast to bare metal and a full repaint, and they believe you, then the chances are they will do nothing, which is what most people do about corrosion.
And if you do nothing about corrosion, you end up with nothing.
