4wd
$50 site donor 2026
I think this is fairly common - I have 10W30 in a WGen9500 that gets pretty hot - but I’m reading here that low Noack might not mean low consumptionI've used almost every lubricant they sell BUT their motor oil.
Sometimes that excitement feeling does not happen overnight. It does with their high pea content fuel system cleaner most definitely and fairly soon. I can remember way back when O'Reilly did 5 qt of Pennzoil Synthetic or O'Reilly Synthetic with a house filter for 20$. First time I used synthetic oil it felt more responsive, smoother, etc. Always felt better after a service from my butt dynoNever really got excited about it….
Even during those F&F days……
Sometimes that excitement feeling does not happen overnight. It does with their high pea content fuel system cleaner most definitely and fairly soon. I can remember way back when O'Reilly did 5 qt of Pennzoil Synthetic or O'Reilly Synthetic with a house filter for 20$. First time I used synthetic oil it felt more responsive, smoother, etc. Always felt better after a service from my butt dyno![]()
Advance Auto stocks it my areaI keep forgetting I want to try their fuel system cleaner. Heard great things about it…..
Ya I don't know how people quantify "better". RL was very popular in BMW circles back in the 2000's because everyone thought API SN would cause their engines to fail early.Watching a few youtubes on Redline and reading posts on Reddit and people absolutely swear by the stuff. I've decided to give the 5w30 a try. Seems to be better than Amsoil based on what others are saying. Definitely isn't cheap but I ordered from FCP Euro. They don't seem to charge anything extra so if I don't like it I won't use it again but if I do like it , $18 a change moving forward for me (shipping), not bad.
USPS lost a used oil analysis from last summer.I'll be posting some Redline High Performance VOA's IF, and apparently that is a big if, the USPS finds where my samples went.....
Same here, I really like their gearbox oils. From new I've used Redline MT-85 in our E46's 5-speed manual and Redline D4-ATF in the power steering. Also too, and from new, I've used D4-ATF in our Honda Element's auto trans. Good stuff.I used their gear stuff; it is an excellent product.
Over time, I've experimented with all of Redline's gearbox oils in the E46. First transmission OCI was at 1,000 miles. I was surprised at how much metal came out with that first drain.Their D4 ATF is by far the most popular fluid in BMW manual gearboxes among enthusiasts. Smooth shifting, good on track (not too thin like D6).
Only smoother fluid I had in my manual BMW was Motul MultiATF.
I used their D4 on track. 101-102f ambient temperature. But that is E90. Could be also gearbox thing. I have HPL MTL 75W now in, and definitely not as smooth and too thin when warms up.Over time, I've experimented with all of Redline's gearbox oils in the E46. First transmission OCI was at 1,000 miles. I was surprised at how much metal came out with that first drain.I refilled with D4-ATF. I used it for awhile but it felt too thin. Tried MT-90 next, too thick. Experimented back and forth between MT-80 and MT-85 before finally settling on MT-85. Climate is a big factor in choosing which to use.
Scott
Here’s a few used oil analysis I have performed on Redline oil and gear oilWatching a few youtubes on Redline and reading posts on Reddit and people absolutely swear by the stuff. I've decided to give the 5w30 a try. Seems to be better than Amsoil based on what others are saying. Definitely isn't cheap but I ordered from FCP Euro. They don't seem to charge anything extra so if I don't like it I won't use it again but if I do like it , $18 a change moving forward for me (shipping), not bad.
3.5 HTHS with a Noack of 6 in a low hour motor that specs 10W30 -I see that the WGen9500 is a Generator, and you say it gets Hot. Have you verified Oil Temperatures with a Thermal Probe after the Generator has been turned off? You may be fine with the 10w30, I am thinking that where you live a 5W-40 or 15w40 would be better for your Generator. I did this with my Lawnmower Engine, I took a temp with an infrared gun at the Oil Filter, but the oil temperature with the Thermal Probe was like 30 Degrees Higher. On these Air-cooled Engines I am looking at HTHS Numbers and the film thickness of the oil at 250 Degrees Fahrenheit.
The 10w30 you are using might be fine, the only way to know is if you can take some Oil Temp Readings.
I love Noack Numbers, but on my Lawnmower engine that is air-cooled like your Generator, I saw 245 Degrees Fahrenheit, I stepped up to a thicker oil with better HTHS Numbers. Again, there is more to an Oil than there Noack Numbers, I just cannot get away from the Numbers.
There is a member here that said something about running Mobil 1 15W-50 in his Generator in Florida and others that used a thinner oil, it could have been 5w30 or 10w30, they had issues. Again, it is HTHS and Film Thickness that you only get from a thicker oil when the Weather is Hot, or you are running your Generator for a very long time.
