Don't over tighten your spin-on oil filter!
wwillson
Staff member
Colorado
A friend of mine, who lives in Houston, sent me this picture of what was left of his spin-on oil filter after he finally got it off the car. Left me pretty much speechless. He should call whoever over tightened it and let them get it off.
Originally Posted By: Reddy45
Quick lube place?
He doesn't change his own oil, usually. Unless he did it and didn't want to admit he over tightened it! LOL
I wonder if the gasket fell off and they tightened it until it stopped leaking.
Ouch! I've had to stab in a screwdriver to get a stuck filter off before, but he had to shred that thing to remove it. What was it installed with, a rattle gun?!
The lack of the gasket and the damage on top would have me checking his mounting base. Hopefully that’s not messed up.
I think the gasket is deliberately made of a type of rubber that swells in contact with oil. They are always harder to get off than the originally tightening torque would suggest. Anyone who has removed a filter that they put on themselves will know this. You would think the trade would know it too.
Modern cartridge filters that use an O ring seal that is largely independent of tightening torque are a big step forward.
I had to completely chisel one off of a 1.8 Isuzu Diesel in a 1984 Chevette back around 1988-89.
It took over 3 hours. U N B E L I E V A B L E... never one as bad since then.
why not use a filter adapter with a 1/2 inch breaker bar.
Thats what I have been using for years. Hasn't failed me yet.
If you have room, and most cars don't, you can use a strap wrench
Originally Posted By: David2431
...but if you do, make sure to have one of these!
https://shop.advanceautoparts.com/p/lisl...l+filter+wrench
Memorial Day Weekend a year ago-after messing for a couple of hours trying to loosen a spin-on on a jetski I chased down one of these. Had it off in 15 seconds or less.
Lisle make many useful items but this not as good as many others of the same principle. They cost more but are worth it.
