Hey guys, new to the board here. I have a 95 camaro z28 LT1 engine A4 trans. it has 162,700 miles on it. i drive it every day. short trips, city driving, and highway. usually drive it pretty easy with the occasional heavy foot driving. the last two days it has been driven hard due to tuning and dialing in.
i live in upstate SC so summers are hot and winters usually don't see the 30-40* range until january/febuary. i got the car with 114,000 miles on it 3 years ago. it had a havoline/texaco oil change sticker in the window, so i'm guessing it had havoline in it previously. i put castrol gtx high mileage 10w30 w/ either an AC delco filter or Purolator or Pureone. then i tried havoline 10w40 once. after that a friend talked me into regular castrol 10w40 w/ lucas (snake oil stabilizer).. then valvoline w/ lucas. then i found out that the lucas was garbage, so i changed it. currently has valvoline 10w30 and wix filter.
help me out with what i should go with next? i don't know if synthetic is worth it at this point or not. i also don't know if i should step up in the weight of it with my miles. from what i can tell purolator or wix seem to be the best choice in filters.
