- Joined
- Oct 3, 2023
- Messages
- 895
Donaldson is a pretty big name in industrial filtration, we have a few air filtering installation assemblies at our plant in a climate controlled room, never have touched their oil filters but have heard they are pioneer of synthetic micro-glass media that goes by the trade name Synteq. Their filters are normally rated at 99% at 15-17 microns depending on the size of the filter and 90% at 10 microns.
These go for 10 dollars a piece at FleetPride. Wanted to check these out for a while to see how well they hold up in automotive applications. You can get these around 8 dollars elsewhere online. These filters are pretty heavy for their small size, the can walls are thick, base-plate is heavy, the media is supported by a beefy coil spring at the bottom end & a nice thick gasket. Bypass valve is like a hard fiber material which should seal well when submersed in oil.
Counted 48+1 pleats which includes the metal crimp seam. The media endcap lip diameter is around 70mm with a endcap to endcap height of 2-1/8" Nitrile ADBV is a bit of a buzz kill for the kind of media this carries, its normally made for industrial equipment that is rated by the hour than miles. Its pretty a beefy ADBV so might be able to go 10K miles if you wanted to.
These are 3/4-16 threaded filters, should fit most Toyota. Bypass setting range is 11-17 PSI which is about the same as the FRAM Endurance FE3614. Cut one sample for the sake of science and for your visual entertainment. Enjoy.
Donaldson P551132 - New
- Mewbs
- 19
New cut open Date MFG 7-26-21. Cross-ref LF16011 = PH3614. 48+1 pleats, nitrile ADBV. 2-1/8"...
