This article show a lack of semiconductor procurement knowledge. At the start of the pandemic, the auto companies cut their chip orders because they forecasted a big auto sales slowdown. Well, that slowdown was pretty short; companies shot themselves in the foot. Problem is, for chip manufacturers changed over to other orders. In this business, changover is a very big deal; it takes time and can be millions of dollars. Additionally, the Renesas (Japan) fab had a large fire and was down until May 2021; I believe they are back at full capacity now. Renesas makes nearly a third of the microcontroller chips used in cars around the world.
not sure how accurate, but it sure sounds gloomy for the foreseeable future still...
Oh great just another way for Ford to screw up their vehicles.This article show a lack of semiconductor procurement knowledge. At the start of the pandemic, the auto companies cut their chip orders because they forecasted a big auto sales slowdown. Well, that slowdown was pretty short; companies shot themselves in the foot. Problem is, for chip manufacturers changed over to other orders. In this business, changover is a very big deal; it takes time and can be millions of dollars. Additionally, the Renesas (Japan) fab had a large fire and was down until May 2021; I believe they are back at full capacity now. Renesas makes nearly a third of the microcontroller chips used in cars around the world.
Companies like TSMC (biggest chip mfr) prefer to make the densest chips which are more profitable.
After the physical chip is fabbed, its firmware, or low level code, must be programmed for its intended use. NVIDIA is known for programming automobile chips.
There is only 1 car company who programs their own chips which turned out to be a big boon, as existing chips could be reprogrammed enabling chip repurpose.
FYI, Ford has announced plans to bring chip firmware programming un house, which I believe is a really smart move. I would expect others to follow suit.
Vertical integration, bro. Software is king and will be even more so going forward.Oh great just another way for Ford to screw up their vehicles.
Maybe Ford should pay more attention to making better vehicles and leave the chips to others.Vertical integration, bro. Software is king and will be even more so going forward.
I'll have to see that to believe it. Unless they already owned a fab, I doubt they could get up and running that quick.Hyundai/Kai is reporting they will be up to 100% production by end of year.
This is after they decided to produce their own chips in early 2021.
Fabbing the wafers is only the 1st problem; programming the firmware is the bigger problem.I'll have to see that to believe it. Unless they already owned a fab, I doubt they could get up and running that quick.
Spot on. I forgot the Hyundai fabs! The companies I worked for, Novellus (deposition) and Lam Research (etch) shipped machines to them.Hyundai was in the chip business before they made cars. I don't know if that division was bought out or only renamed.
It'd be smart for Ford to make many different things with one chip type and different software, then they could jump the backlog at factories by ordering a large number.
I have to believe they already do, but who knows? With the current problems you can order a large number, but that doesn't mean you are going to get them. I'm sure a company like Ford would have more pull and money to get what they want, but sometimes they can't be made fast enough.It'd be smart for Ford to make many different things with one chip type and different software, then they could jump the backlog at factories by ordering a large number.
Unless it is a new chip design they are probably tweaking existing firmware for each chips. This is the preferred way to do things as less changes means less risk, and firmware is one heck of a thing that is harder to debug (other than ROM code or verilog). For combustion engine they likely are tweaking as needed unless a completely new architecture is needed on a completely new generation of stuff. It is probably easier to have the chip or controller companies (Denso, Bosch, Deiphi, etc) to do the whole architecture then share between multiple customers.This article show a lack of semiconductor procurement knowledge. At the start of the pandemic, the auto companies cut their chip orders because they forecasted a big auto sales slowdown. Well, that slowdown was pretty short; companies shot themselves in the foot. Problem is, for chip manufacturers changed over to other orders. In this business, changover is a very big deal; it takes time and can be millions of dollars. Additionally, the Renesas (Japan) fab had a large fire and was down until May 2021; I believe they are back at full capacity now. Renesas makes nearly a third of the microcontroller chips used in cars around the world.
They may order chips the same way some OEM (say Denso or Bosch) order them from the asic vendor (say Motorolla or Renesas), they likely would come with some reference design that OEM build on top of, charge some extra for profit, and Ford decided they can either negotiate a better deal if they have another source (internal, 2nd vendor) to compete with, and build their own based on the asic reference design.I have to believe they already do, but who knows? With the current problems you can order a large number, but that doesn't mean you are going to get them. I'm sure a company like Ford would have more pull and money to get what they want, but sometimes they can't be made fast enough.
It used to be that Motorola a lot of silicon to the automotive industry even to the point of them making ECMs, and GM had an in-house electronics divison(Delco Electronics). A lot of the Denso/Hitachi/Oki branded silicon in Japanese cars were actually made by NEC and Hitachi - who are now Renesas.This article show a lack of semiconductor procurement knowledge. At the start of the pandemic, the auto companies cut their chip orders because they forecasted a big auto sales slowdown. Well, that slowdown was pretty short; companies shot themselves in the foot. Problem is, for chip manufacturers changed over to other orders. In this business, changover is a very big deal; it takes time and can be millions of dollars. Additionally, the Renesas (Japan) fab had a large fire and was down until May 2021; I believe they are back at full capacity now. Renesas makes nearly a third of the microcontroller chips used in cars around the world.
