Does Valvoline Restore and Protect help with DI intake deposits?
Just wondering, since the PCV system is continuously dumping oil vapor into the air intake. Any reports or claims of Valvoline Restore and Protect vapors helping with DI intake valve deposits? Seems like Valvoline Restore and Protect in the crankcase would be a lot easier than walnut shell blasting.
Be nice if it did. I floated a thought a couple years back that I'd hoped someone would engineer an oil additive that was designed to boil off, go through the PCV system and attack the back of the intake valves.
You get DI intake valve deposit from oil that gets past the valve stem seals combined with crud that comes through the PCV system along with impurities from the intake that get past the air filter. And then there is no gasoline to wash all that down into the combustion chamber. Yes, it should help. Installing a catch can also helps... a little, but not much. Best option: do a GDI cleaning with one of those PEA based IVD deposit cleaners (there are a few) and then use Vavlone Valvoline Restore and Protect. That would be the most sensible option.
Probably not much but it's worth a shot. If Valvoline Restore and Protect can dissolve carbon it's possible.
If it's able to soften deposits inside an engine I would say in the Long Long Term it would keep intake runner deposits slightly softer where intake cleaners could have more effect. There's really nothing to lose by running Valvoline Restore and Protect, but again, I wouldn't expect noticeable results with
any kind of short timeframe. Would be very hard to quantify.
I remember Dave from HPL stating it might be possible with their oils. My feeling was it’s not 100% or tested for in any way. I’d give Valvoline Restore and Protect the same odds. So it can’t hurt to try!
It’s the same price as most mid tier oils so no harm no foul. At best it helps. At worst it’s still oil.
Hopefully it's not harsh on seals or anything else. There are many threads and pages and pages of info and I'm sure it has been discussed but too much info to keep up with ...
I do use a lot of Valvoline products like engine oil, gear oil, ATF, brake fluid, power steering fluid, etc. so nothing against them.
Yeah I’ve argued such. As we don’t know for certain right now. Anecdotally it appears it may potentially eat up the coating on the black Toyota OEM oil drain plug gaskets… still doing some testing on that. Not sure it matters much though
At about the 12 minute mark in this video, the Valvoline guys says that the main cleaning is piston deposits, but it may help with intake valve deposits via the PVC system.
