12:25 he does state that Valvoline Restore and Protect can help with IVD buildup as you're still getting some of that oil on to the valves.
No one knows other than Valvoline at this point.What is in the oil that makes it clean over other similar tier oils. That is my interest.
A guy on the Colorado FB group said he picked up a ZR2 with the 3.6L that had 28k miles on it. Engine was spotless but had significant buildup on intake valves.
Valvoline Restore and Protect doesn't meet dexos "officially" so I've held off using it but I am intrigued based on what they engineer said about it's potential to help mitigate IVD. On the flip side I also wonder if AMSOIL Signature Series/HPL can achieve a similar result.
"The ECM for the 3.6L has extremely retarded exhaust valve timing for the cruise regime. That creates an EGR effect by allowing the exhaust valve to still be open for quite a while when the intake valve is opening. The downward moving piston pulls in some fresh air, and some exhaust. The piston begins to push up, and some of the inward rushing exhaust is actually pushed back out the intake valve (and also out the exhaust valve). This allows exhaust to meet oil mist on the intake tract to form deposits there. The oil mist comes from the positive crankcase ventilation (PCV) system, and is most evident during heavy load. The carbon buildup is there by design. It’s to mitigate exhaust emissions, but at the cost of engine longevity. Go figure."
Actual quote: "The Valvoline Restore and Protect, I think, will help that (IVD) some....". It seems he's entirely speculating.12:25 he does state that Valvoline Restore and Protect can help with IVD buildup as you're still getting some of that oil on to the valves.
I think it's a bit of a leap to assume that because the oil can clean pistons, that it will also clean intake valves, especially when the deposits are largely made up of oil additives.
Detergents and dispersants help keep an engine clean, but they actually make valve deposits worse according to the studies I've seen.
For me , it’s CRC Intake Valve Cleaner every 10K - 12K miles along with the occasional sustained 4K RPM’s for 20 minutes on the interstate to cook off intake valve deposits (Italian Tune Up) . Conversely , I would like to think that a decent synthetic oil from Valvoline , Mobil , SOPUS , etc. would not contribute to intake valve deposits to the extent oils before say 2020 may have contributed to the issue . If Valvoline Restore and Protect could help with intake valve deposits in GDI engines - that would be a plus !Actual quote: "The Valvoline Restore and Protect, I think, will help that (IVD) some....". It seems he's entirely speculating.
Alkylated naphthalenes?What is in the oil that makes it clean over other similar tier oils. That is my interest. The plan mandated emission warranty requirements make the engines last too long, the auto manufactures is to make cars such garbage that we will want to lease them.
But never has burning oil, and money, felt so good LOL.If someone wants to lower IVD using certain oil, than that would be oils with MB229.52 approvals because Noack is limited to max 10%. However, there is no oil that will fix poorly designed PCV.
Valvoline Restore and Protect is just another ILSAC oil with new marketing hype.
That's been the general theory but from what I've seen they all get deposit buildup. There really isn't much you can do and it doesn't appear to be a problem in most cases. Most synthetics today have a Noack <10%, especially EP lines. Noack actually isn't the only concern either. Ash level, oxidation resistance of base oil and solvency. The oil coming in contact is still whole oil in mist or vapor form.I remember reading that low SA or low-SAPS oil or ACEA C3 (mid-SAPS) are better if concerned with IVD.
Not sure if this was an undisputed fact or not since there are so many variables when it comes to IVD. I finally kind of gave up on it.
For example Pennzoil Platinum Euro L 5w30 is MB 229.51 & C3
I think 229.51 is mid-saps & HTHS >= 3.5 and Noack <= 10%. No?
What are the major differences between 229.52 and 51?
It wasn’t a theory. Lubrizol did study where VW 502.00 left 167% more deposits than VW504.00. We posted that in Euro section numerous times.That's been the general theory but from what I've seen they all get deposit buildup. There really isn't much you can do and it doesn't appear to be a problem in most cases. Most synthetics today have a Noack <10%, especially EP lines. Noack actually isn't the only concern either. Ash level, oxidation resistance of base oil and solvency. The oil coming in contact is still whole oil in mist or vapor form.
It would be interesting to run a test of MB229.52 vs FS HPL, Red Line and AMSOIL Signature Series in terms of IVD's.
HPL mentions how "These oils are formulated with specifically chosen esters that can help minimize intake valve deposits"
HPL No VII may be really good for limiting them if the VI is one of the causes. Or oils in general with less VII.
...so it's not unreasonable to think Valvoline Restore and Protect could in theory do the same. Especially if it's capable of removing piston deposits. I think the issue is not enough of it would come in contact with the valves to make a difference.
