- Messages
- 179
- Location
- Forest Hill MD
Just wondering. I see a lot of anecdotal evidence, but is there any hard data from carefully-controlled tests?
Troy
quote:If this were the case wouldn't you have 0 engine wear metals? There must be some metal to metal. Higher film strenght of a synthetic will support reduced wear metals.
Originally posted by pedaltothemetal: Think for a moment. Is there any metal to metal contact when using any oil dino or synthetic. Leo
quote:Hmm, wonder where I've heard that before?
I have never seen convincing UOA data showing that the INITIAL rate of engine wear is lower using synthetic vs good conventional oils
quote:Just a few PARTS IN A MILLION in wear metals. I still can't believe this amount will increase mileage measureably. Better sealing of the cylinders during combustion due to the higher film strength, yes. I only feel extra power at part throttle. At full throttle, I can't feel it because I have so much hp and torque. Although it will likly be measured on a dyno. These are my seat of the pants observations! Leo [ May 23, 2003, 03:18 PM: Message edited by: pedaltothemetal ]
Originally posted by msparks:quote:If this were the case wouldn't you have 0 engine wear metals? There must be some metal to metal. Higher film strenght of a synthetic will support reduced wear metals.
