Who really knows?
WRT the metallic adds one sees in VOAs/UOAs most oils are more alike than different.
They use different proportions of each additive, but even some oils using sodium also use moly, so I don't think you'll see real metalic additive clash.
There are a number of organic additives that might or might not be present in any given oil that we can't see, though.
Vavoline oils typically seem light on metallic adds, but produce very pretty UOAs.
Either Vavoline is using an industry leading basestock, which I doubt, or Valvoline is using organic adds to bolster its oils, which seems likely.
I would avoid mixing across brands or published formulations.
So, I'd mix Pennz with Pennz, QS with QS (both are SOPUS, but different add pack suppliers), Valvoline with Valvoline and so on.
I'd avoid mixing the Mobil Super oils with M1, since they clearly have different add pack designs.
M1 oil do not contain sodium, while MS oils do.
Still, if I had five quarts of different brands and grades to get rid of, I could see putting this mix in a beater for a run.
Might not be optimal, but wouldn't cause any measurable harm either.
Sorry I was unable to provide any real answer to your question.
I don't think there is any clear answer.
I'm not a fan of blending.
Some here are, and I'm pretty sure that their engines will run until the car they're in is junked, just like mine.
