Then I suggest you do not deviate from that grade.It does not say others would also be suitable. "AS SHOWN". The only one "shown" is 0W-20. Period.
All CAFE driven - many other new car OMs show only one viscosity too. Toyota OMs however do have a statement to use higher viscosity oil under certain driving conditions. CAFE hasn't brainwashed them entirely just yet, lol.It does not say others would also be suitable. "AS SHOWN". The only one "shown" is 0W-20. Period.
It's pretty obvious when they tell you what grades to use. Motor fails, and if they see that you put the wrong oil in there? That there's ticket to voiding your warranty. I don't know why you guys enjoy playing stupid.Were does any ower's manual say it "must" be used ... meaning "required" and not "recommended"?
They would have to prove that thicker oil was used, and that it caused the damage. No car company has a real tribologist that could technically prove that 5w30 blew-up an engine that specified/recommended 0W-20 or 5W-20. Not gonna happen unless someone was using a W rating way too thick for the cold start winter conditions.It's pretty obvious when they tell you what grades to use. Motor fails, and if they see that you put the wrong oil in there? That there's ticket to voiding your warranty. I don't know why you guys enjoy playing stupid.
Ditto using 5W30 on my 2015 Civic, wife's 2020 Honda Pilot and our 2012 Tundra.it's all I run, for my 12 civic, and my 19 2.0 T accord, 11 ranger, 95 4runner. all get 5/30..
there is ZERO difference in mpg's from 0/20 to the 5/30, I test this on several occasions and never saw a difference. so from around the 25K miles mark they all get on grade oil.
I’m curious if using 5w30 will help with oil consumptionDitto using 5W30 on my 2015 Civic, wife's 2020 Honda Pilot and our 2012 Tundra.
Which brings us back to the original point made by @kschachnIt does not say others would also be suitable. "AS SHOWN". The only one "shown" is 0W-20. Period.
Looks much better indeed!
Why...... If they call for 0w20.....then use 0w20.....pretty simple...Basically all that require 0w20 oil
Nope, you are totally wrong. Anything other than 0W-20 is forbidden because Honda only specifies 0W-20.
2019 Civic Warranty booklet (came with the car):
"The warranties in this booklet do not cover: • The failure of any part or accessory due to: - Abuse, misuse, accidental damage, or acts of nature. - Improper installation or maintenance. - A low fluid level or the use of a fluid other than specified by Honda."
Owners Manual:
"...oil of suitable viscosity for the ambient temperature as shown."
A snippet of said owners manual is provided below and verifies "as shown" is only 0W-20.
Why 25k miles?it's all I run, for my 12 civic, and my 19 2.0 T accord, 11 ranger, 95 4runner. all get 5/30..
Wrong answer. If the book states you must use 5w30, 0w20, 15w40, etc. only, that's it. That **** ain't a suggestion.
i do in mycivicJust like the title states, does anyone run 5w30 in their new Honda?
Yep, I'm still waiting to see an owner's manual where the call out for oil viscosity is "required" and that there is a specific statement that says the engine warranty will be null and void if the called out "required" viscosity is not used.The problem is in all my years I've never seen an owners manual that said "MUST". I've seen should, recommended etc. But never must.
