The throttle body is a NECESSARY restriction. When it is NOT a restriction, you are not in that lower RPM range, because of course, you are now at WOT
Hey, I floor it while operating between 1500 and 3000 rpm quite regularly!
My Mustang verification was done at the drag strip. It picked up .5Mph repeatably.
But that doesn't provide any information about low-end torque!
During cruise, the plenum is in a constant state of vacuum, with the only thing feeding it being the throttle body. The flow of the air through the throttle body is NOT "fluid". It is broken by the blade. The ONLY time it approaches anything NEAR fluid is when you are at WOT. . .
It's definitely still fluid across the throttle body!
From Dictionary.com:
flu⋅id/ˈfluɪd/[floo-id]
–noun
1. a substance, as a liquid or gas, that is capable of flowing and that changes its shape at a steady rate when acted upon by a force tending to change its shape.
–adjective
2. pertaining to a substance that easily changes its shape; capable of flowing.
3. consisting of or pertaining to fluids.
4. changing readily; shifting; not fixed, stable, or rigid: fluid movements.
5. convertible into cash: fluid assets.
. . . And of course this does not apply to the area we are discussing; low RPM put around town power, where the plenum is usually under significant vacuum.
I thought we were still debating WOT situations, too! I only got into this because you said:
How is something in FRONT of the MAF and TB going to take away low-end power?
Though I certainly am responsible for bringing fuel economy into the same discussion.
Also, off-side: Dyno runs usually start ~3,000RPM.
Sure, but it depends what you're going for. For a daily driver, it's useful to know the effects of modifications at the lower revs. K&N provided the dyno plot for the Mazda3 (my car, slightly different engine) from 2300 rpm to 6900 rpm. It's odd that the peak gain is made at 4800 rpm and the two plots converge both before and after that point. There is no significant gain from the aftermarket intake at 6900 rpm and very little at 2300 rpm. I'm not applying that to this conversation or drawing any conclusions from it. I just thought it was unusual.
http://www.knfilters.com/dynocharts/69-6010_dyno.pdf
You are missing my point.
It's possible, but I was having fun with it anyway!
Your point seemed to be that tuning the intake ahead of the throttle has no effect on performance, except for the effects of friction losses at WOT. To me, it's still a mass of air flowing toward the valves, and I think the inertia of that mass would affect the flow primarily at WOT, but also even with a partially closed throttle; it's still pulsing, to some degree, as it crosses. I accept that you may be correct in that the plenum volume could negate that effect for daily driving situations or, even more likely, that the effects become so small as to be negligible. We'll have to agree to disagree unless someone can provide some credible testing or references about this specific subject, but I'm willing to concede that fuel economy in a throttled engine is probably not affected in any significant way by the installation of an aftermarket intake, as eljefino stated a few pages ago. I still believe that an oversized intake can adversely affect full-throttle performance at low revs.
