Does 10w30 blend,synth sheer in summer?
stamford, CT
Hi all! Something I've looked up,n maybe some more info out their.
Does a synthetic blend sheer in stop n go, and what about in 97 degree F humid temps? Based on a 3000 mile oil change? Or 6 months? I know synthetic would be a lot more stable. I'm it hin too try a Sunoco synthetic blend 10w30 in a 98 LeSabre soon! But the traffic here sucky.brakes,brakes..summers really humid,pressure ,heat.think it will hold up between April through September,and within 3000 miles?
Absolutely a Syn Blend will hold up
Thanks! Times I've run conventional oil ,98 Corolla I had , and a 95 neon, havoline...it was good ,even th traffic.but when I got too 3,700 miles 6 months,opening the drain bolt...thick molasses black,stressed n thick looking.you can feel,the car wanted it evacuated lol.you could sense it . ..
Usualys ,at least with the buck,it's not as bad but with synthetic .
Basically,does humid summer heat cause oil too thin out too?
I use 10w30 conventional non syn blend in my beater year round slowed down consumption so I'm guessing it's not shearing much if at all. I also use in my air cooled lawnmower no makeup oil for 7 months use and air cooled generator I used in the summer a few times once for 3 weeks straight 24 hours a day
