Do Zero Weight oils have better base oil?
Originally Posted By: ZZman
Do zero weight oils have to use a better base oil in order to make the zero grade?
I think they do.
All zero weight oils are race oils, as far as I know. I would definitely imagine they'd use very good base stocks.
huh?
GC? M1? Not race oils.
Originally Posted By: Rand
question makes no sense. unless you mean
0w30 vs 10w30 type thing?
How so Rand?
I would think that a Zero weight oil must use a better base oil than say a 5 or 10w oil in order to go that low in grade. I am just curious.
Maybe a better question would be: What allows an oil to be a zero weight grade?
I think he meant 0w30 0w-20 not 0w-0 if you can call it like that.
A problem answering this inquiry is the definition of "better" base oil.
How so Rand?
0wXX isnt a 0weight/grade anything.
I thought maybe you were talking about some kind of super race oil that isnt defined. so they just call it 0 weight.
but to answer your question
a 0w20 vs a 5w20 for example
the 0w20 could use thinner basestocks with more VII so its not necessarily better.
it all depends on the product and the engineering that went into it.
and quality of ingredients.
so an example
any 0w20 vs non-syn 5w20... probably the 0w20
honda semi-syn 0w20 better than ... Pennzoil Platinum 5w20.. no.
Mobil 1 0w20 better than Mobil 1 5w20? who knows
etc. There is nothing beyond a very generic broad generalization.
There are two ways to get a 0w oil:
Use alot of VII or a higher quality base stock
Most oils use one method or the other. Some use both methods. You can usually tell by comparing viscosity index and volatility.
Here is one possible way to produce a Full Synthetic 0W30:
Base Oils:
PAO 40cSt – 3-5%
PAO 6cSt – 7-15%
PAO 4cSt – 35-50%
Ester 5-15%
PI Package – 7-9%
Viscosity Modifier (VII) – 2 to 10%
Viscosity – 10.25 cSt
HTHS – 3.1
NOACK –
Originally Posted By: simple_gifts
those aren't 0 weight oils I think the inference is.
Exactly.
0w-xx is not "zero weight." It's 0w.
0w requires a higher VI base oil/oils. That can be achieved via a blending of high VI base stock and viscosity improvers. Due to the need to pass volatility tests, there cannot be too much viscosity improver, therefore there tends to be more PAO or ester base stocks because of their much higher VI.
