I have seen people with both, just wanted to get a head count on who is using either.
I would be changing the transmission fluid with the oil, and was looking at using these directions
Have a grade 8 nut welded to the back/bottom of the drain pan so that when it is on ramps, the fluid will run towards the drain plug. Weld first, then drill hole, and fit appropriate bolt into nut with teflon tape.
Pump sounds easier, but cost more. Plug means car needs to be up, but oil changes would be the time anyway.
[ February 16, 2005, 08:39 PM: Message edited by: Shaman ]
