Originally Posted by billt460
Originally Posted by geeman789
I can't see new oil in a small sealed container being " dirty ... ". Oil delivered in bulk, coming out of a who knows if it has ever been flushed and cleaned tanker truck ... maybe.
I can't believe that oil manufacturers don't filter their oil ...
This ^^^^^^^^^^^^^^
I mean really, does anyone actually believe new oil in a sealed container has "contamination" in it that can harm your engine bearings...... Unless it has passed through the oil filter first? That's preposterous.
Even the cheap re refined stuff goes through a rigorous filtering process. That's all part of the procedure of how it goes from crap oil, sucked out of a rusty old tank in the back of Auto Zone, into the bottle, and back on the shelf.
Yet we're supposed to believe the high priced, newly refined synthetics are sold full of harmful garbage that can damage your engine, unless the stuff is filtered first? Complete nonsense.
Perform a particle test on new oil and you might just be surprised at what is found in it--I know that I was and I trust Jim Allen's results implicitly. Granted we are not talking about it being "full of harmful garbage", but there are certainly particles contained in some oil samples that are large enough to cause a bearing streak.
The two oils in question were mainstream too--Mobil Super 5000 and Pennzoil Ultra and they both had a few particles that were larger than 100 microns so that means by pre-filling, you are sending those particles to the bearings before it is filtered--if the pre-fill oil contains one of the particles. To each his or her own, but unless one has performed tests and obtained data, one should not be so quick to label something as "nonsense".
