Do u always wipe off the oil filter mount area?
Michigan
When changing the oil filter do you always wire the mount area off before installing the new filter or sometimes just inspect it?
I always like wiping mine.
Originally Posted By: Zee09
Wipe and shine!
I keep around a jar of Meguiar’s metal polish just for this!
I was just thinking about this last time I changed the oil. Out of habit, I normally wipe it off. And then I thought...why bother? There is probably half a quart of dirty oil left inside the engine, wiping a few extra drops off isn't going to make a difference. Probably more likely to leave lint from the paper towel behind.
As for "inspecting" it, I couldn't see the gasket surface anyway unless I used a mirror. I always look at the filter after a few miles to make sure nothing is leaking.
Originally Posted By: AVB
Why are you inspecting the base, is it leaking?
It takes five seconds to wipe and look. You never know if something unusual comes up. IMO having a smooth clean base ensures a proper seal with the freshly oiled gasket on the new filter.
If you never wipe , over time you will have issues.
Interesting, on some of my cars I couldn't even see the mount, so I just checked the old filter for the gasket. On my Focus its easy to see the base and it always looks fine so I just put the new filter on. Never had a leak from the filter gasket so nothing bad has happened so far.
Originally Posted By: Chris142
Yes. That also doubles as a way to make sure that the oring didn't stick. I have been getting a lot of that lately.
I only see stuck orings on Fram Ultra and Wix filters. I don’t know why.
But yes, I always wipe the mounting surface.
I have no issues with that. I do wipe it, clean it, and I never use a paper cloth but a new microfiber
cloth. I don't want debris, old gaskets, etc. But honestly it's about cleanliness and I don't want oil dripping on my driveway and I don't want my fresh filter dirty with old oil and hard to grip. After I install the filter I wipe it too as it is an indicator if I have a leak.
I see guys dip a fresh filter in the oil pan and use old oil on the gasket. They gum up the fresh filter and make it a mess. I don't like sloppiness.
Egads.... They are mad!
