Do Tire Repair plugs have a expiration date?
VA
I like to keep tire repair plugs in every vehicle i drive, do these things have a expiration from just sitting waiting to be used?
I could see the rubber cement or the plugs drying out over time.
According to safety seal which has been recently bought by a conglomerate, Yes. It is 5 years. SS use to label their production date on the packages.
I do the same thing. Keep them in each vehicle. Except I keep a little plug repair kit in the glove box or console inside the cars. I probably need to replace mine they been in there so long. At least not expensive like T.D. says.... Well worth it to keep some in your rides.
On a related question, does the plugged tire have an expiration for the inserted plug ?
IOW - for a "new tire" (less than 4,000 miles) with a very small plug.
Used this kit with the glue per directions, into an almost new tire and it has now been reassigned to be a "spare" but I wonder if it could be put into rotation.
https://www.amazon.com/dp/B000ET9SAA
Car is an AWD and has now 4,000 miles so trying to keep tire wear even.
[sorry about the thread resurrection]
Most of those rope type "plugs" use the rubber cement as a lube to facilitate inserting the plug easier. Once it flashes it keeps the plug in place until the heat from driving basically vulcanizes the sticky coating on the plug into the rubber of the tire and makes the repair "permanent". As long as the coating is still sticky when pulled off the plastic card they are on, it's gonna work. Mine dry out in the garage after about 5-6 years so get tossed then. I'm thinking of trying this to keep in the cars. No glue to dry out.
Call me skeptical....
I've made dozens of repairs with the rope ones and none have failed for the remainder of the tire's life, so might not fool with what works. Still, curious about them since I don't have to keep rubber cement in a hot car, which ALWAYS volitizes away.
I agree the regular plugs work fine when done correctly. I question the ability of your space gun version to install properly :)
I have read (but not tried) that you can use more traditional rubber cement - not the tire specific stuff which is fast drying - but you have to wait 15 -20 minutes before adding air. Presumably it would keep in the car longer.
The tire itself is only good for 6-10 years, and tires usually have some kind of wear when they get plugged, so it should last the remaining lifespan of the tire it is installed on :unsure:
Absolutely never have plugged a tire, always have it patched from the inside.
True, that is the preferred method.
However, when the puncture is outside the repair area, my regular patch location refused (liability) and suggested self-repair/plug
