Have you checked engine operating temperature?
The thermostat could be sticking.
Pretty sure it will throw a code if the temp doesn't get up to where it should be
Do fuel injector cleaners cause carbon fouling in the sparkplug?Pretty sure it will throw a code if the temp doesn't get up to where it should be
I had an 86 Corolla I used too much carb cleaner on in an attempt to fix a rough idle.Do fuel injector cleaners cause carbon fouling in the sparkplug?
I put a new denso oxygen sensor my mpg got reduced from 16 mpg to 15.5 mpg. The engine power is alright. May be a I will change the sparkplug and check the catalytic converter.Former mechanic and 3800 owner here. That's a normal-looking O2 sensor in my opinion, and you said it was cycling normally. I suspect your fuel efficiency woes are elsewhere. Is the engine low in power? Could be a plugged cat. As long as you're checking the brakes with a temp gun, might as well shoot the cat too. And give it a couple of love taps to be sure the catalyst isn't rattling around inside. It should temp at least a couple hundred degrees higher than the downpipe. If not, well, it's up to you what to do about that....
