Do costs in a US shop to machine an existing rotor vs costs in a Chinese or Indian shop to cast and machine a rotor from scratch and ship it to the US come out fairly similar? It's an interesting study.
Did you take into account the cast iron rotor structure, time under heat and the force excreted by the braking force?Total myth. Rotor sizes/dimensions are engineered for specific vehicles, their mass, and specific brake systems. I have several vehicles with OE rotors on them after many years and miles. They are no thinner than required. Ever see or handle the front rotors on a newer-gen Chrysler minivan? They're massive.
True.
If the original rotors are within spec, why would you replace them? Especially with some inferior Chinese junk that entices with a low price.
Internet myths. Still waiting for someone to explain to me how cast iron warps. It doesn't. It would require over 1800 degrees F to permanently change the shape of cast iron; modern passenger car brakes get nowhere near that hot. Rotor "warpage" is generally due to improper installation, rust-jacking, deposit build-up, cocked calipers, improperly torqued lugnuts, and other reasons which are almost always the fault of the installer.
The science and data are easy to find, and people still perpetuate the myths.
Yep, almost a certainty.Just dropped by track day forums for several popular cars, it appears that even though they get their rotors incredibly hot most of the "warping" is just residue of the pads on rotor built up unevenly.
Man in 2007 it was replace pads rotors together, always. Even under free maintenance. They’ve become so mainstream and get the money orientedBMW dealerships cut rotors without removing them from the car.
Exactly. Think about Japanese cars where routinely a fair about of rotor surface is not swept by the pads. The rotor then rusts and there’s a large band or orange stripe that protrudes more and more over time.Internet myths. Still waiting for someone to explain to me how cast iron warps. It doesn't. It would require over 1800 degrees F to
We turn rotors and drums. Hardly ever have to do drums anymore though thankfully. But if I’m able to sell rotors I’ll just sell rotors because I hate machining them.I thought @AutoMechanic said his dealer(s) still do it.
It's more common than you'd think.
I always understood that the "myth" around rotors being built with less material was primarily on today's more modern econoboxes. New rotors for many small cars are so inexpensive that it doesn't make sense to turn them, and I could believe they were meant to be one-time use as such.
I rarely have rotors turned because of TIME. Even if O'Reilly picks them up and brings them back I still have to wait. If a job is forseen I'll order inexpensive (usually closeouts) rotors and just be ready to slap them on. Or I just bill the customer for a whole brake kit which is usually only $120‐160 for most vehicles for new rotors and good pads.
Rotor is measured for thickness before they are turned.If the rotor exceeds the minimum allowable thickness after turning, they are reused. Otherwise the rotor is replaced. In most cases, there isn't enough stock left to reuse with todays rotors. The rotor would be much more prone to warpage being on the thinner side.
Don't all steel rotors develop surface rust if they get wet? Mine get surface rust after I wash my car. It's gone as soon as you drive the car and use the brakes...The same shop they wanted to turn my altima‘s rotors because they had surface rust..
Do you do them on the vehicle or off on a lathe? What does your shop charge for pads/resurface?We turn rotors and drums. Hardly ever have to do drums anymore though thankfully. But if I’m able to sell rotors I’ll just sell rotors because I hate machining them.
It’s $189.99 including labor just got to buy the pads separately which are usually ~$70ishDo you do them on the vehicle or off on a lathe? What does your shop charge for pads/resurface?
I passed by AZ on way home and got new Duralast Elite to swap fronts. Old ones go back tomorrow. Worn but not crazy and at least I know my son will have new pads all around. Took it out, did the bedding, nice, smooth, quiet after that initial crazy transfer material grind. First time that happened I was like *** but after a couple replacements I expect it and they work good.
I had also ordered a new sway bar end link from RA. I replaced one last year but the AZ penalty was $40 vs $10 so only did one. Life got in the way and hadn't ordered yet. Well when I swapped front pads today, good thing I ordered that end link already and it will be here Friday.
Because they don't last very long after they have been turned and seem to warp easily. The cheap Chinese junk you are talking about seem to work good. I bought some new rotors for my Civic a long time ago and they are still working great.If the original rotors are within spec, why would you replace them? Especially with some inferior Chinese junk that entices with a low price.
Oh and to add we only have a standard old school brake lathe. No on car stuff. I have used the on car ones before in school and I’ve noticed they never cut as smooth and you usually can’t cut just one pass on them.It’s $189.99 including labor just got to buy the pads separately which are usually ~$70ish
True.
Not saying it always happens, but it can. Get some foreign material between the rotor and the wheel bearing flange and hit it hard with an impact. It will warp and it can be verified with a dial indicator. I've seen it.Internet myths. Still waiting for someone to explain to me how cast iron warps. It doesn't. .
Buddy of mine keeps trying to convince me of this. Also tells me the run out is from the bearing which is why if you replace the rotor it vibrates again in 10K miles.What's your opinion on out-of-spec. runout on a newly installed rotor? Do you think that could cause a brake to develop pulsations prematurely that feels like "warpage"?
