Does that filter have stronger media or is there somthing else special about it?quote:
Originally posted by Triple_Se7en:
My GM Colorado has no valve in the AC Delco PF-61 filter or in the engine.
Collapsed/breached media ..and, perhaps, reduced oil flow (if you reach the pump's relief limits). I would think that your oil pump relief valve would have to fail for the can to blow ..maybe notquote:
Originally posted by 95_carvan:
If not what are the dangers of running one in a application where the "regular" filter has a bypass?
Wouldnt oil pressure be more than 21psi most of the time?quote:
Originally posted by LARKBILL:
Actually his Colorado does have a filter bypass valve located in the block, part number 25014612, according to the catalog it opens at 21 psi. The PF61 however does not have an ADBV.
