I want to do my own change from now on.. However, apart from keyboard, I am not handy on anything much less turning a wrench.
So, can the pros tell me how to do an oil change by meself?
1. What do you use for jacking up the vehicle? ramp or jackstands? which is safer? I assume that ramp is easier for beginners since jackstand slipping is a dangerous situation.
2. After draining the oil, putting the drain bolt back on with new o ring, what else to do apart from sticking a new filter? i.e should the filter be loaded with new oil? or empty is okay?
3. Pour fresh oil and start the vehicle while on ramp. However, if the vehicle is tilted (if jackstand is not used), the oil level might read wrong.. but thats probably okay since the quantity is 4 ltrs in sump and .3 in filter hence 4.4 should do.
4. Drive off the ramps and reset the OLM... Am I missing something?
First of all, I dont know where the filter is located and if it is cartridge or canister.. 07 mitsubishi outlander btw.
