Originally Posted By: brsmith
With Pennzoil Platinum at $20.50 for 5 quarts at Wal-Mart, there is no way I would go back to dino.
I have an '06 Corolla S 1ZZ-FE, Auto and I have used PP until the last two changes where I am using PU now.
I use a Fram XG-3600 filter on it which has more volume than the stock filters and fits perfect. Bypass is within a lb or 2 of the stock filter.
I am also using a Filtermag MB-300 (300lb pull force) magnet on the filter.
I just changed the oil tonight at 78,438 miles and 6,200 on the PU. You could still see through the oil on the stick and it was still dead on the full mark.
As good as the engine looks inside the valve cover and how well it is running, I just don't have a problem spending $40 for what would be 2 severe service oil changes. I have a Fram Sure Drain plug on it and I changed the oil in 20 minutes and didn't spill a drop on the driveway.
Best of all, I will take the used oil back to Wal-Mart in a spare PP bottle and they will recycle it for free.
The peace of mind that my engine is protected and as clean as it is just seems worth it. I add 10 oz. of Motorkote engine treatment every fourth oil change. I bought a gallon of it awhile back and I don't see it hurting anything.
I will be surprised if this engine doesn't go 300K before it is tired. It is only supposed to have 128 Hp, but I have put many a car to shame with it on the highway.
I'e got the same car as the OP and you. I'm at 172k and will be TICKED if I don't see at least 400k.
And I will with no problems. 7-8k OCIs with any 5w30 bought on sale.
Bill
Bill
