Discount oil in Oz.
At SCA 1-11 July
Castrol Magnatec 10W40 semi-synthetic
API SN/CF and ACEA A3/B4
$23 for 5L (regular price $50)
She Helix HX7 10W30 semi-synthetic
API SN-Plus
$40 for 5L (regular price $57)
At Autobahn in Oz 1-22 July, 2021
60% off Nulon Semi-Synthetic oil, $18 for 5L
10W40 API SN, ACEA A3/B4, JASO MA (good for the bikes)
5W30 API SN & ILSAC GF-5
Castrol Magnatec Bio-Synthetic 5W30 (full synthetic)
API SN & ILSAC GF-5
50% Off, $25 for 5L
Autobarn have Castrol EDGE 5L 0w40 diesel for $19.99
I'd run it in my petrol engine for that price!
That is fantastic price, i'm contemplating if i should buy 2 Castrol diesel 0w40 or Havoline 0w30 C2.
I have 20L of Delvac CI-4 10w30 and 10L of Castrol 5w30 A3/B3 at home already.
At Repco, to 27 July
Nulon 5W30 Long-Life full synthetic
Dexos1-Gen2
Half Price at $30 for 5L (for the good car)
Nulon 15W40 mineral
API SL/CF
Half Price at $18 for 5L (for the beater)
Just saw that the Nulon Street & Track 25W60 is on sale at SCA in Oz at $34 for 5L (it normally costs about $45)
ZDDP (zinc) = 1900 ppm
Molybdenum Dithiocarbamate (MoDTc) = 400 ppm
KV 40 = 276.9 cSt
KV 100 = 23.92 cSt
VI = 108 (probably a monograde)
SA = 0.7 %
TBN = 5.4
Until 22 Aug
In the spirit of heavier grades, I saw snapped these at Lordco today. Enjoy.
At SCA in Oz, 12 Aug to 22 Aug (today)
The big 6L jugs of Nulon full synthetic are half price.
5W30 Long Life, API SN, ILSAC GF-5, Dexos1-Gen2.
10W40 Fast Flow, API SN/CF, ACEA A3/B4.
Both are $40
Also the 6L Penrite synthetic oils are 30% Off, at $50
Full Synthetic 5W30, ACEA 5/B5 and Ford 913-D (high ZDDP oil at 1050 ppm Zinc & TBN 10.1, but thin at KV100 = 9.6 cSt, classic Ford 913-D)
Full Synthetic 10W40, API SN/CF and ACEA A3/B4
Also at Repco
Castrol Edge 5W30 A3/B4 Full Synthetic & Full SAPS
ACEA A3/B4, BMW LL-01, MB 229.5
So, TBN above 10, Noack Volatility below 10%, HTHS at 3.5 cP or above, and high ZDDP at about 1000 ppm Zn (hence SL rather than SN or SP, the API chemical limits rules, not the quality of the oil)
This is my go to oil, running it in the 2.5L Nissan X-Trail (Rogue) right now.
The oil is half price at $35 for 5L
At AutoBarn in Australia, 22 Aug to 5 Sept.
Gulf Western 10W30 semi-synthetic
API SP and ILSAC GF-6A
70% Off, $10 for 5L
That is an amazing good price at $2 per litre, and you have the natural advantages of 10W30 such as its low Noack volatility and its shear stability, coupled with the new tests added to SP & GF-6A, like timing chain wear protection and LSPI protection.
KV100 = 10.6 cSt
PP = -30C
TBN = 7.2
SA = 0.7 %
70% Off, $10 for 5L
KV100 = 10.6 cSt
PP = -30C
TBN = 7.2
SA = 0.7 %
My oil stash is getting bigger and bigger o_O. 20L Delvac 10w30 CI-4, 10L Castrol Edge 5w30 A3/B3, 10L Castrol Diesel 0w40 C3 and now another 10L of GW 10w30 API SP.
  • Like
Reactions: SR5
I know, I too have ample oil.
Gulf Western isn’t a brand I usually pay attention to, but I’ve looked them up and yes they are on the official API list. So this is a real API SP 10W30 oil, and there has been significant improvements in going from SN to SP, so you know it’s a good oil.
And that price ! One red back gets you two jugs .....
I like Gulf Western BlackTak 5% molyplex grease. 1 tube last forever. has been in my Territory lower balljoint after i swap it years ago. 800kg 4-ball EP weld point compare to the normal 200kg.
http://www.gulfwestern.com.au/wp-content/uploads/2015/07/Black-Tak-Molyplex-40052-1.pdf
Thanks for that, good to hear, looks like GW is now on my radar.
That’s the benefit of following quality industry specs, and producing good PDS data sheets with real numbers measured to ASTM standards. It allows people to trust your product.
Looks like I’m lining up for my first GW purchase.
Gulf Western has always been good oil. They just entered the market with some low cost options which put some people off. Look at the weights of some of their 'comp' oils, 1000hp E85 oils.
  • Like
Reactions: SR5
Repco: Valvoline Engine Amour 10w40 API SP Semi syn. $25 for 5L. Not to shabby....
Nice, I’ve not used the newer API SP EngineArmour, but I’ve used lots of the older 10W40 semi-synthetic DuraBlend that was API SN/CF & ACEA A3/B4.
The older SN 10W40 EngineArmour had a Noack Volatility of 10.2% according to the Valvoline PDS, which is nice and low. I’m sure the newer one is much the same.
Edit: just looked it up, the newer SP 10W40 Engine Armour is still Euro rated with A3/B4. That should suit most cars.
At AutoBarn, 6 to 30 Sept.
Castrol GTX 15W40 UltraClean semi-synthetic
API SN/CF and ACEA A3/B3
65% Off, $13 for 5L
Also, 20% Off Cooper oil and air filters. I use these filters a lot.
At SCA 16-26 Sept.
Valvoline Super Diesel 10W40 semi-synthetic
API CI-4/SL & ACEA E7
50%Off, $46 for 10L
From the SCA site:
Features​
  • 10 Litre, 15w40, API CH-4/SJ, ACEA A3/B3.
  • Reduces soot agglomeration, sludge formation and resists thermal breakdown to keep your engine clean
  • High Viscosity helps reduce oil consumption in worn and older engines with higher tolerances
  • Mineral formulation suitable for use in light and heavy duty diesel engines without DPF, see our Parts Guide to find the right oil for your vehicle
So mineral oil and 15w..... Still good buying all the same :)
Tempting but my 15w 40 semi/min stash is at about 41L level atm 5w30 Full Synthetic, about 26L. 10w40 Full Synthetic down to 20?L. time to stocktake Full Synthetic's I'm getting low LOL!
Edit: checked stock levels and corrected..
