Dirty Intake Valves with DI
Pennsylvania
So after posting a message about my VW Golf AllTrack and getting responses about having to clean the intake valves after a while, I got to wondering. Why do diesel engines not seem to suffer from dirty intake valves like DI gas engines seem to do? I know that if you run the intake valve at a high enough temperature, the debris will not collect. Is that what they do in diesel engines? Are there other tricks up the diesel builder's sleeve to prevent intake valve deposits? After all, these guys have been running DI for decades. What gives?
Errrrr, some diesels are notorious for forming deposits in the intake.
Oil vapour from crankcase ventilation plus soot from EGR can seriously clog up the intake manifold and cake onto valves.
You never had an old TDI with the VE injection pump. While the intake valves didn't get the buildup, the EGR valve got it buildup first.
Then came ULSD regulation which helped tremendously with the soot, but before that, we did the "EGR mod" using VAGCOM, where one would dial back on the EGR PWM to just before a CEL would be triggered, so less EGR, less buildup, but more NOx output. Or people would get the EGR delete and delete the EGR altogether, at the risk of not being able to turn off the engine.
I don't think Honda's have a reputation for buildup- but installed a air/oil separator and dump it biannually of black sludge,
