Originally Posted By: mclasser
I've had a few sets of directional tires on my cars in the past and to my understanding, having them mounted the wrong way may affect wet traction more vs. dry traction. During rain, the clearing of water from the treads may be adversely affected due to the improper tread direction. I would definitely take it back to the pinheads at Walmart and have them re-mount it correctly with you standing next to them.
Tread design is important to dry traction to some degree. A lot of the reason for longer lasting tires with better traction is from modern computer modeling.
Directional tires are pretty much designed to channel water either out the back and or to the sides. If you've got it reversed, some designs might be more likely to hydroplane because it channels water to one point where it gets trapped and forms a wedge of water. Some directional tires have large longitudinal channels, so I'm guessing it wouldn't be too severe, although they're designed to channel water to the channels and out the sides.
This definitely has a direction, but they have narrow channels out the sides. I think it's designed to remove some water out the side channels, and reversing it would simply channel more water to the inside channel.
I had Dunlop SP Sport 9000s on my car, and if they're on backwards they will trap water at dead ends.
At one time I thought maybe the belts might be laid out in a specific way, but apparently that's not the case.
