Differences between shocks/struts
Michigan
While brakes shopping, I've also been in the market for shocks and struts for my Cobalt. I was pretty much going with Monroe (OE spec/Senstrac ), but was reading about the AC Delco branded stuff, it caught my attention. According to what I was reading/watching, they say they are very well built. And the prices are not much more than Monroe (40 bucks in shocks, about 30 in struts), which made me wonder if they might hold up better in pothole laced MI...
Heck, I'd even consider Sachs stuff, but they only come in shocks for my car....And no one mention Sensen....or I;ll have to break this out....
you wont go wrong either way. I'm not sure that AC/Delco aftermarket is any better than Monroe..... they might even be the OEM. personally I use Monroe - of course, Tenneco is just down the street and I know people who worked in their testing lab
Shocks don't control the geometry of the suspension.
Struts DO control the geometry of the suspension.
Both are correctly called a "suspension damper" since their primary purpose is to dampen spring oscillations. A strut will take the place of a suspension pivot point, usually the upper. On a SLA suspension, the pivot points are the upper and lower ball joints. These are the points where caster is measured.
Macpherson struts encapsulate a spring under tension as part of the strut assembly. There is a modified strut suspension used on the 80s Camaros and 79-04 Mustangs where the spring is compressing in between the lower control arm and the engine cradle.
Or was your question more towards differences between brands of dampers?
Remember that AC Delco has three lines: Advantage (cheap [censored]), Professional (mid-grade aftermarket), and GM Original Equipment.
Another good choice would be Gabriel Readymount quick struts up front, and their shocks in the rear. There is a rebate promo on a set of four through the end of October.
I seriously doubt AC Delco makes any of their replacement shocks and struts. They are probably just re-labled Monroes.
Originally Posted By: Joshua_Skinner
What's the question?
Whether the AC ones would be any better than the monroe ones....
I've different reviews for all kinds of stuff, from brakes to oil filters, but not much on shocks/struts from the car companies (like Delco or Mopar, for example)
Though in this case it is AC delco parts....
While true, still makes me wonder where they are sourced from...
Like the brakes currently on the car, are made by akebono, while most of their Delco sourced aftermarket lines are Raybestos.....
Yep....thought I threw that in there...guess now....
Its ok, you got a free lesson on one of my pet peeves about part names. I grew up watching racing so I use words like "anti-roll bar" and "upright" to describe parts.
My ACDelco struts are made by Bilstein. Part of the FE4 package on my GXP. If they make them for your car, and you can afford them Bilstein makes some excellent stuff.
Well, they make shocks, no struts for the Balt though....
I hate when ricers/tuners call an adjustable billet strut assembly a "coilover". Technically my stock Maxima has coilover shocks in the rear already, and McPherson struts in front.
Oh, and I almost forgot, SENSEN
I bet the Monroe OESpectrum struts are relabeled OEM units. That was the case with the OESpectrum struts I put on the Fit last month, and from others that have used them. The OES shocks were house-brand Monroe, though.
