The API, with the new SP rating, is sticking to its guns and not allowing a gasoline SP rating for any diesel oil with more than 800 PPM phosphorus due to catalytic convertor poisoning. In fact, xw40 diesels oils that have higher than 800 ppm phosphorus and we’re also granted a SN rating will not be getting the S rating starting next year. While some Bitoggers like to make their own rules that it’s OK to use high phosphorus oils if you do not consume oil, that is not the viewpoint of the API. So it’s more of a what’s good for mankind thing. Obviously you could also cut out your cats with a hacksaw as well if you thought you wouldn’t get caught. As for longevity, I have got 200,000 miles on a gasoline powered vehicle that never used diesel oil. By the way, it’s pretty hard to measure if the efficiency of your cats is going down unless they actually measure the NOX in a sniff test. With something like 200 million gasoline powered vehicles in the USA, the API has to deal with broader concepts than what individual Bittoggers do.
