diesel oil in a 98 f150 v6
I've used Exxon XD-3, 15W-40, in my F-150 with no problems so far, but since I have only 230,000 miles on the truck, it may be too soon to tell.
darkdan, If you are addressing this to me, then yes, lately I've been putting the little v6 to good use. From high speed trips to towing 2 to 3k lbs at highway speeds. The havoline 5w20 has held up well, but with summer and the 100+ temperatures was looking for an added measure of protection and a 5 to 6k oci at a reasonable price. Obviously the m1 is a no brainer, but 6.5 qts a 5+ dollars...well, you can do the math. A reasonable solution seems to point at the diesel oils. They seem to work well in the semi-desert heat.
