I suspect the battery weight is too high at this time. Maybe in the 1 ton class, but I suspect in 18 wheeler the power demands are too high. In cars the fact that under typical usage power required is low, and under load the requirement is short cycle, means that the system is not particularly heavy. Scale up for higher duty cycle and system weight gets problematic. Higher duty cycle or just higher power, the scale gets bigger.
Might be worth trying in something like a 1 ton though. Maybe i’m wrong. But i think hybrid is eating its cake because of low duty cycle and low peak demand.
In a diesel locomotive, the weight bump is in the “eh” class, as it can help traction, even though in the end, weight is weight and it hurts going up a hill. But what would a battery pack for that application weigh? it’d be a trailer of its own, and the wiring… huge! serious copper there. Design that system and then you could just scale between these bookend systems (passenger car and locomotive) every different system.
