That's thermally conductive, not electrically conductive right?Here is my arctic ceramique thermal paste on my tsp coil pack. Not sure if it helps or hurts, just have a ton of the stuff and trying to use some of it before I die
Right.Yes. Says so right on the bottle.
That is perfect for the under side of ignition modules, it helps transfer the heat away from the module to the mounting.Here is my arctic ceramique thermal paste on my tsp coil pack. Not sure if it helps or hurts, just have a ton of the stuff and trying to use some of it before I die
This includes boats, motorcycles, lawn tractors, feild tractors, combines, seafood etc, etc.I been using regular grease or vaseline on all my electrical connections and in bulb sockets for 50 years with no problems of any kind. Still have every vehical that I have bought over the years and all run to this day without any electrical problems.
I'm sure it's a good product for the intended purpose but that is not a dielectric grease and should not be used as one.This is what I use. It does not break down and seals really well:
Ox-Gard Anti-Oxidant Compound
Ox-Gard Anti-Oxidant Compound contains prime grade zinc and is formulated with metallic zinc to create a compound that enhances electrical and thermal conductivity which is used on high power crimp connections and stud bolt mountings. When the connection is tightened, the grease is displaced...www.gardnerbender.com
The OP was looking for an alternative to dielectric grease. OX-Gard is a solid choice and works as intended. The issue with dielectric grease is it needs to be reapplied over time. OX-Gard can not only be used as dielectric grease, it protects, seals and make better electrical contact.I'm sure it's a good product for the intended purpose but that is not a dielectric grease and should not be used as one.
The product you linked is not an appropriate alternative to dielectric grease. Yes I’m sure it works as intended but it is not a dielectric grease nor should it be used as one.The OP was looking for an alternative to dielectric grease. OX-Gard is a solid choice and works as intended. The issue with dielectric grease is it needs to be reapplied over time. OX-Gard can not only be used as dielectric grease, it protects, seals and make better electrical contact.
OX-Gard conducts electricity so on multi pin connections you have to use it sparingly to avoid shorting out connectors. If you are a sloppy user of this product then dielectric grease is your best choice as it does not conduct electricity.
My understanding about dielectric lube(silicone lube) is that it is not that it has anything in it to help with better electrical contact. It's just the opposite, It doesn't have anything in it to prevent good contact, is a great lube and also a very good moisture barrier.
Silicone pastes/lubes(e.g. brake lube) are similar however, they may have ingredients/chemicals in them that could prevent that wanted better electrical contact. And silicone product won't deteriorate rubbers & plastics.
Petroleum product or anti-seize products aren't the optimal products for these components however, I know tons of folks who do indeed use use them for things such as battery posts, brake sliders, electrical contacts etc.
By the very definition of the word you've shown that OX-Gard is not a dielectric grease. The two terms are mutually exclusive.The OP was looking for an alternative to dielectric grease. OX-Gard is a solid choice and works as intended. The issue with dielectric grease is it needs to be reapplied over time. OX-Gard can not only be used as dielectric grease, it protects, seals and make better electrical contact.
I am struggling to remember the brand of electrical anti seize anti corrosion grease we used on copper to copper bus work and copper to steel grounding. It looks just like copper anti-seize and its probably the same thing it even says you can use it on nuts and bolts as anti-seize, I have a bottle of it out in the shop and its as old as the hills....
I use it on battery terminals and ring terminals, just about anything I want to have a good conductive surface but protection against corrosion.
Copper Anti-Seize is probably just fine in it's place.
