Hi all, new here.
i've been having an issue with my aftermarket LED headlights flickering and dimming for the past few months while braking on my 2019 GMC Canyon Denali. originally i thought it was just a bad bulb since it was only a single bulb on the driver side, so i contacted the place i bought them from and they sent me a new set of Morimoto 2stroke 4.0 under warranty to replace the 3.0s i had for 2.5 years. voltages from the battery and alternator seemed good through the charging system and the resting battery voltage while a little low was still sitting above 12 volts
while waiting for the new lamps to be shipped to me my alternator died, had that replaced but still the headlight issue persisted. once i got the new lamps things got a little worse, at least worse from what i noticed. flickering persisted but for the first few minutes of start up these lamps would dim and flicker randomly from both headlights while driving and not just braking like i was noticing before. upon further investigation of my voltage, i noticed my starting voltage was running at 15 volts for a few minutes before settling down and staying at a steady 14.4-14.5 volts at times it would spike to 15.5 volts for a few minutes. would rarely get to below 14.4 volts.
thinking it was a load issue, i replaced the battery, given that its 5-6 years old i figured it was time to replace it, but still no difference, my mechanic replaced the alternator again thinking that the new one could be a faulty, same issue. did some diagnosis, disconnected the communication connector for the alternator and the voltage dropped to its default output for the alternator. thinking it was a grounding issue, we jumped the alternator to the negative battery and it seemed to do something, so we ran a #4 ground from the alternator to the negative battery terminal. the voltage dropped a little bit for a few days and at a normal voltage of 13.9-14.2 the headlights ran normally, and now the voltage has been back to the same figures and the headlight issues still persists. i guess the lower running voltage was just there until the BCM/ECM re-calibrated to the new ground
at this point we are thinking the problem could be a failed current sensor not relaying the right load back to the BCM which is calling for a higher voltage, but would this cause the headlights to flicker? the current sensor only comes with the negative battery harness and to completely replace the harness is not an easy job on these trucks, looks like the fuse box in the engine bay has to come out and the negative that mounts to the block sits above the front differential and is a pain to get to.
anyone here have any thoughts or opinions/ recommendations to check? has anyone seen such a thing?
i should also not, that when braking the dome lights would also dim for a half second but given that they aren't LED they are not as reactant as the driver/ballast on the LED bulbs.
i'm also an electrician by trade, the only issue is i'm not fully familiar with the system controls in a vehicle, so troubleshooting without fully knowing the order of operation is a little more difficult and i need to do a bit more research on the systems structure so any help would really be appreciated
