didnt change it
fairfield,CA
1995 honda civic its my mom car. Well did oil change syntec blend and mobil filter. She ran a 4500 oci I topped off like crazy due to many oil leaks. Well I did the oil change and kept the mobil on? Is it true filters become more efficient over time? I'm thinking about keeping it on for a third oci. Yes no ?
Originally Posted By: hate2work
Yes, they filter better right up to the point of failure( bypass ). I would change it.
Can going into bypass mode cause major engine damage or just no filtering causing increased wear?
You might want to try one of the many High Mileage oils in order to try to seal up some of those leaks. Keep the filter changed also.
Just no filtering. Its unlikely it will bypass over two 4500 mile or so runs. I ran a EaO for two 5k (or so) runs and the insolubles were lower after the second run than the first.. (.2 vs .3)
I would do two OC with it removing the filter and dumping old oil out then put it back on.
don't get carried away here.
I don't know the specs for that filter (synthetic?), but one of the things often thought but wrong is that synthetic filters can run longer. Since they are much more efficient, they fill up faster.
